PiicoDev Pressure Sensor MS5637 - Raspberry Pi Guide
Updated 08 March 2025
This guide will help you read barometric pressure data from your PiicoDev® Pressure Sensor with a Raspberry Pi single-board computer.
In the video, we use a PiicoDev Platform to keep everything safe and secure.
For this tutorial, we'll assume you're familiar with using a Raspberry Pi like a desktop computer - connected to a keyboard, mouse, monitor and with an internet connection. If you need help getting started, have a look at Chapter 1 of the Raspberry Pi Workshop for Beginners.
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your pressure sensor to the adapter via the PiicoDev cable.
connect-piicodev-temperature-sensor-to-raspberry-pi
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header and connects to a sensor with a PiicoDev Cable.
Enable I2C
raspberry-pi-enable-i2c
Install PiicoDev
Download the Example Script
Download this example script: main.py (right-click, "save link as")
Save this file wherever you like to keep your programming projects. For this tutorial, I'll save mine in /home/pi/PiicoDev and change the name to pressure.py to give it some context.
Run the Example
Open the example script in Thonny and run the script with the green play button. (Hint: View the files menu with View > Files). You should see barometric pressure measurements in hectopascal, which is equivalent to millibar - a commonly used unit for describing barometric pressure: 1hPa = 100Pa = 1mbar.
piicodev-pressure-sensor-demo-code
Above: Pressure data streams up the Shell, while the Plot shows historic data.
Remix
Did you know you can also infer altitude from air pressure? Comment out the pressure print statement and uncomment the altitude print statement. Run the script again and now the Pico will infer altitude-above-sea-level from air pressure. There can be a bit of error here since your local weather conditions will affect the reading. You can optionally pass in the local air pressure at sea level to the read_altitude() function to correct for weather effects. You can find the current air pressure at sea level for your area with an internet search.
piicodev-pressure-sensor-ms5637-altitude-measurement-remix
We can now measure air pressure from our PiicoDev Pressure Sensor, and use it to infer altitude.
If you make something cool with this starter project we'd love for you to share it on our forums! And if you'd like some help with this guide, start the conversation below - We're full-time makers and here to help!
sensor pressure altimeter altitude barometric
