PiicoDev Precision Temperature Sensor TMP117 - Raspberry Pi Guide
Updated 02 May 2022
This guide will help you read temperature data from your PiicoDev® Precision Temperature Sensor and a Raspberry Pi single-board computer
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Ensure the default address is set
For temperature sensors with an address switch labelled "ASW" (hardware versions v12 and above), make sure the first switch is ON and the rest are OFF.
piicodev-tmp117-default-addresspiicodev-tmp117-default-address
For earlier revisions of the temperature sensor, the address was set by a solder jumper on the back. In this case, make sure that address 0x48 is selected.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your temperature sensor to the Adapter via the PiicoDev cable.
connect-piicodev-temperature-sensor-to-raspberry-pi
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the temperature sensor with a PiicoDev Cable.
Enable I2C
raspberry-pi-enable-i2c
Install PiicoDev
Download the Example Script
Download this example script: main.py (right-click, "save link as")
Save this file wherever you like to keep your programming projects. For this tutorial I'll save mine in /home/pi/PiicoDev
Run the Example
piicodev-temperature-sensor-example
Pictured above: The temperature data streams up the Shell and graphs in the Plotter (View > Show Plotter). The temperature sensor gets warmed up quickly, then cools slowly.
All going well, you ought to see temperature data streaming up the Shell window.
The example also reads temperature in Farenheit and Kelvin - Modify the print statement to call the appropriate variable as you like.
eg.
print("It's " + str(tempF) + "°F")
Now we can easily read temperature in Celsius, Farenheit and Kelvin.
Tip: Open the Plotter (View > Plotter) to see a nice plot of your temperature data
Connecting Multiple Sensors
It's possible to connect up to four temperature sensors to the same PiicoDev bus and read them independently - they each require a unique address. In the connect section, we set our sensor to the default address (0x48): where only the first ASW switch is ON. To read from more sensors, they need to be configured with unique addresses. For example, the second sensor should have the ASW2 switch ON, and the rest off. The third should have the ASW3:ON and the rest off - and similarly a fourth sensor.
piicodev-precision-temperature-sensor-multiple-sensorspiicodev-precision-temperature-sensor-multiple-sensors
The following example will read two sensors independently. This example looks similar to the first example in this tutorial, except now the initialisation functions are passed the asw argument. This is a list of four numbers that represent the positions of the ASW switches. sensorA has the first switch set, so asw=[1,0,0,0]. Likewise, sensorB has the second switch set, so the second element is 1 and the rest are 0: asw=[0,1,0,0]. This logic can be expanded to a maximum of four sensors.
# PiicoDev TMP117 - reading multiple sensors
# This program independently reads the temperature from two PiicoDev TMP117 precision temperature sensors
# Each sensor should have its ASW switches configured to match the asw argument during initialisaiton, eg.
# sensorA: asw=[1,0,0,0] so the first switch should be ON and the rest OFF
# sensorB: asw=[0,1,0,0] so the second switch should be ON and the rest OFF
# this logic expands to a maximum of four sensors
from PiicoDev_TMP117 import PiicoDev_TMP117
sensorA = PiicoDev_TMP117(asw=[1,0,0,0]) # initialise the sensor
sensorB = PiicoDev_TMP117(asw=[0,1,0,0]) # initialise the sensor
# Advanced users may prefer to set the address explicitly, instead:
# sensorA = PiicoDev_TMP117(address=0x48) # initialise the sensor
# sensorB = PiicoDev_TMP117(address=0x49) # initialise the sensor
    # Read and print the temperature in various units
    tempA = sensorA.readTempC() # read from sensor A
    tempB = sensorB.readTempC() # read from sensor B
    # print both results
    print("A:" + str(tempA) + "    " "B:" + str(tempB))
    sleep_ms(1000) # delay 1 second
References
TMP117 datasheet
raspberry pi temperature piicodev precise tmp117 precision
