This guide will help you read distance data from your PiicoDev® Distance Sensor and a Raspberry Pi single-board computer
- A PiicoDev Distance Sensor VL53L1X
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Distance Sensor to the Adapter via the PiicoDev cable.
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the temperature sensor with a PiicoDev Cable.
Enable I2C
Install PiicoDev
Download Example Code
Download the Example Code (right-click, "save link as"). Save this somewhere that makes sense - I saved mine to a PiicoDev directory in my home-directory.Run the Example
Pictured above: The distance data streams up the Shell and graphs in the Plotter (View > Show Plotter). The measured distance increases and decreases as I move my hand back and forth in front of the sensor.
All going well, distance data will begin streaming up the Shell window.
Tip: Open the Plotter (View > Plotter) to see a nice plot of your distance data
