Let's read colour data from a PiicoDev® Colour Sensor with a Raspberry Pi and create a colour sorting machine. This guide will cover connecting the hardware, downloading some example code and remixing it.
- A PiicoDev Colour Sensor VEML6040
If you prefer not to use the PiicoDev Adapter for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Also, some colourful objects like coloured paper, fruit etc. will be useful for test-driving our colour sensor!
If you haven't set up a Raspberry Pi to be used like a desktop computer before, head over to our Raspberry Pi Workshop for Beginners to get started.
- Introduction - Colour Theory Crash Course
- Connect the Sensor to your Pi
- Download Example Code
- Example Code - Read RGB data
- Remix - Fruit Sorting Machine
- Conclusion
- Resources
Red, Green Blue
The Red, Green, Blue (RGB) colour model is an additive colour model, meaning that it mixes (adds) Red, Green and Blue light to create many colours. RGB is used for displaying the colours on the screen you are reading this article - each pixel emits a certain amount of Red, Green, and Blue light, which - when mixed - creates the colours you're seeing.
Hue, Saturation, Value (Brightness)
Hue is a property that describes the colour of the colour - the colour's identity - red, green, blue, yellow etc. Hue does not describe anything about how bright or intense the colour is.
Saturation is the intensity of colour; A bright red has high saturation, as opposed to a reddish-grey, which has very low saturation.
Value is the amount of light in a colour - A light red has a high value, a dark red has a low value. Usually, this is directly related to light; where there’s light there’s a high-value colour and the opposite in the shadow.
The HSV model is really useful for identifying or classifying colours because the hue property is the base colour. Hue is represented as an angle on a colour wheel, so you can identify a colour using a single variable - the angle. Referring to the colour wheel below, Red is described with a zero-angle, moving through to Green at 120 degrees, Blue at 240 degrees, and back to Red.
Source: https://commons.wikimedia.org
Connect the PiicoDev Colour Sensor to your Pi
Mount the PiicoDev Adapter on your Raspberry Pi and connect your colour sensor to the Adapter via the PiicoDev cable.
Enable I2C
Install/Upgrade PiicoDev
Download the Example Script
Save this file wherever you like to keep your programming projects. For this tutorial I'll save mine in /home/pi/PiicoDev. You might like to change the name of your script for some context eg.colour.py
Double click main.py to open it in Thonny, then click the green "Run Current Script" button.
You should see your Pi printing RGB colour data in the shell.
Above: RGB Colour data streams up the Shell, while the Plot (bottom-right) shows historic data. I first hold a blue object over the sensor and then a red object. Referring to the plot; The proportion of green is very high in the blue object. For the red object, the red channel is clearly higher.
This is the raw RGB data that the colour sensor is sampling - it's useful for sampling emitted lights like an RGB LED. What the RGB model is not so good at is identifying a colour, since the light-intensity information is wrapped up in the RGB values. A dimmer coloured light or a sample held farther away from the sensor means each parameter (RGB) will read less light and it's tricky to infer whether it is the colour changing or just the lightness.
Example 2 - Read HSV data
Now we'll identify some colours that we show the sensor. This is where the HSV colour module is useful because it separates the hue (colour) from the value (lightness). To classify a bright colour then, we can just read the hue, and ignore saturation or value.
Comment out the print statement in the first example (Example 1), and uncomment the code block under Example 2. Now, we are sampling colour in the HSV colour space and using just the hue to classify a colour. By default, the classifyHue() function will return one of the six simple colours covered shown in the Introduction's colour wheel.
Try holding a coloured object in front of the sensor and see what hues are returned - record these values for later.
Above: Classifying different hues - a yellow object is held over the sensor, then swapped for a red object.
The classifyHue() function returns one of six simple colours by default. We can provide the function with our own custom dictionary of hues and labels. For example, we could pass a Python dictionary of fruit names, and their corresponding hues to create a Fruit Sorting Machine.
Near the top of the script, define a Python dictionary with the samples you recorded in Example 2.
A Python Dictionary pairs fruit names with their associated hue - found experimentally. You will get the best results if you use results from your own experiments.
Next, modify the call to classify.Hue(), passing in the dictionary as an argument:
If you get stuck, you can copy the full code below:
fruitList = {
"Apple":20,
"Carrot":35,
"Lime":62
colourSensor = PiicoDev_VEML6040()
### Example 1: Print Raw RGB Data
data = colourSensor.readRGB() # Read the sensor (Colour space: Red Green Blue)
red = data['red'] # extract the RGB information from data
grn = data['green']
blu = data['blue']
# print(str(blu) + " Blue " + str(grn) + " Green " + str(red) + " Red") # Print the data. Printing as BGR so the Thonny plot-colours match nicely :)
### Example 2: Classify the colour being shown - eg. a fruit sorting machine
data = colourSensor.readHSV() # Read the sensor (Colour space: Hue Saturation Value)
hue = data['hue'] # extract the Hue information from data
label = colourSensor.classifyHue(fruitList) # Read the sensor again, this time classify the colour
print(str(label) + " Hue: " + str(hue)) # Show the label and the corresponding hue
sleep_ms(500)
Run the script and observe that our Pi can now identify different fruits (or other objects) by their colour alone! Below, I hold a Lime then an apple over the sensor and the classification is printed in the shell.
We can measure colour in the RGB and HSV colour spaces, and classify different hues. We can even classify different objects by their hue.
