This guide will help you read light intensity data from your PiicoDev® Ambient Light Sensor and a Raspberry Pi single-board computer
- A PiicoDev Ambient Light Sensor VEML6030
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Light Sensor to the Adapter via the PiicoDev cable.
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the light sensor with a PiicoDev Cable.
Enable I2C
Install PiicoDev
Download the Example Script
Save this file wherever you like to keep your programming projects. For this tutorial I'll save mine in /home/pi/PiicoDev and change the name to light.py to give it some context.
Run the Example
Pictured above: The light data streams up the Shell and graphs in the Plotter (View > Show Plotter). The measured light starts at about 200 lux (ambient, office) increases when I shine a light on it, and falls off to about zero when I cover the sensor with my hand.
All going well, light data will begin streaming up the Shell window.
