This guide will help you get started with the Raspberry Pi Pico and the Thonny Python IDE, which has out-of-the-box support for Micropython and Pico.
from machine import Pin led = Pin(25, Pin.OUT) led.toggle()
Writing a Script
from time import sleep
n = 0;
led.toggle()
n = n + 1
sleep(0.5)
Return to the REPL and press Ctrl+D (or use the Stop/Restart button) to restart your Pico. The LED should flash at a steady rate and the shell should begin printing multiples of thirteen.
Installing a Package
