Circuit Playground Express TV Remote
Have you ever lost or broken a TV remote before it's time? Have you ever wanted to spice up the way you change channels or inputs on your TV? Have you got a greedy housemate who always steals the remote off you? If any of these are the case...
#circuit playground express #circuitpython #ir #infra-red
Writing Code Onto MicroPython Boards
You have your shiny new MicroPython or Circuit Python board and you have Installed the Firmware and connected to REPL, but now you want to put your code onto the board. To do this we need to send the files over serial. Luckily Adafruit has ...
#teensy #esp32 #circuit playground #micropython #microbit #circuit python
3D Printing for the Circuit Playground
You’ve made yourself a great project for your Circuit Playground Express, now all you need is a box to put it in. How do you keep your Circuit Playground safe in a housing while still being able to press the buttons and use the sensor...
#3d printing #adafruit #circuit playground express #3d #box #fusion360 #housing
Introducing MakeCode: Adafruit Circuit Playground Express
One of the greatest features of the Adafruit Circuit Playground Express is its MakeCode compatibility. MakeCode is an exciting coding interface that makes coding accessible for those with little or no exposure to how coding works or how it ...
#adafruit #circuit playground express #makecode
CircuitPython vs MicroPython: Key Differences
Have you ever wanted to program your microcontrollers with Python instead of Arduino? MicroPython and CircuitPython bring the ease of Python to microcontrollers by adding hardware support! In MicroPython, Python is largely unchanged other t...
#programming #python #micropython #adafruit #circuitpython #code
Natural Disaster Sensor Project with Circuit Playground Express
There is some wild weather approaching! We need a way to give ourselves an early warning when a disaster strikes! In this project, we will use the Adafruit Circuit Playground Express to make an all in one Disaster Detection Station that wil...
#stem #sensors #adafruit #circuit playground express #detection #disaster #natural disaster
Using the Accelerometer with CircuitPython: Adafruit Circuit Playground Express
At the heart of every Adafruit Circuit Playground Express lies a three-axis accelerometer. This allows us to write programs that take the orientation of the board into account. We can detect orientation and acceleration on any axis. With Ci...
#neopixel #adafruit #circuit playground express #circuitpython #accelerometer #lights #motion
Using the Accelerometer with MakeCode: Adafruit Circuit Playground Express
At the heart of every Adafruit Circuit Playground Express lies a three-axis accelerometer. This allows us to write programs that take the orientation of the board into account. We can detect orientation and acceleration on any axis. With Ma...
#neopixels #adafruit #circuit playground express #makecode #accelerometer #lights #motion #tilt
Infrared (IR) Controlled Lights with CircuitPython: Adafruit Circuit Playground Express
The latest Circuit Playground board, the Adafruit Circuit Playground Express comes equipped with an onboard IR transmitter and receiver! This can be used to communicate with TVs and other household devices. You can also use infrared remote ...
#infrared #adafruit #circuit playground express #circuitpython #ir #remote
Infrared (IR) Controlled Lights with MakeCode: Adafruit Circuit Playground Express
#infrared #adafruit #circuit playground express #makecode #ir #receive #transmit
Sound Reactive Lights with CircuitPython: Adafruit Circuit Playground Express
The Adafruit Circuit Playground Express comes equipped with an onboard microphone that is capable of sensing both amplitude and frequency. This tutorial will walk through a quick sketch using CircuitPython to turn the lights on the board in...
#sound #adafruit #circuit playground express #circuitpython #microphone
Color Matching with the Light Sensor and CircuitPython: Adafruit Circuit Playground Express
The Adafruit Circuit Playground Express comes equipped with an analog light sensor, but it can be used for much more than just sensing light or darkness! The light sensor has a similar spectral response to the human eye. Its connected to an...
#circuit playground #adafruit #circuit playground express #circuitpython #color match #light sensor
Color Matching with the Light Sensor in MakeCode: Adafruit Circuit Playground Express
#neopixel #adafruit #circuit playground express #makecode #color match #light sensor
Capacitive Touch Keyboard with CircuitPython: Adafruit Circuit Playground Express
On the lower left-hand portion of every Adafruit Circuit Playground Express, there is a small onboard speaker and class D amplifier. This allows you to make some pretty loud sounds! The amplifier is also connected to the true analog output ...
#speaker #adafruit #circuit playground express #circuitpython #capacitive touch
Capacitive Touch Keyboard with MakeCode: Adafruit Circuit Playground Express
#capacitive #speaker #adafruit #circuit playground express #makecode #keyboard
Sound Reactive Lights using MakeCode: Adafruit Circuit Playground Express
The Adafruit Circuit Playground Express comes equipped with an onboard microphone that is capable of sensing both amplitude and frequency. This tutorial will walk through a quick sketch using MakeCode to turn the lights on the board into a ...
#adafruit #circuit playground express #makecode #microphone
Visual Thermometer with CircuitPython: Adafruit Circuit Playground Express
The Adafruit Circuit Playground Express comes packed with sensors, and for this tutorial, we are going to learn to use the onboard thermometer (technically a thermistor)! We will take temperature readings with the thermometer and print out ...
#adafruit #circuit playground express #circuitpython #thermometer #thermistor
Visual Thermometer with MakeCode: Adafruit Circuit Playground Express
The Adafruit Circuit Playground Express comes packed with onboard sensors, in this tutorial we will learn about using the temperature sensor in MakeCode. MakeCode is great for a simple project because its block-based interface and pre-built...
#adafruit #circuit playground express #makecode #thermometer
Introducing CircuitPython: Adafruit Circuit Playground Express
CircuitPython is a variant of MicroPython that is designed with ease of use and simplicity in mind, and it works great with the Adafruit Circuit Playground Express. CircuitPython is based on the very popular Python programming language, the...
Our Adafruit Circuit Playground Express Overview
Adafruit has done it again with the new and improved Circuit Playground Express. This new version of the Circuit Playground is packed with even more sensors, and capacitive touch ready connection pads. This is a great board for makers ...
#arduino #adafruit #circuit playground express #circuitpython #makecode
How to get started with Circuit Playground
Have you heard about the Circuit Playground? It's the new all-in-one electronics platform from Adafruit. It was created to bring all the fun features of electronics and physical computing to makers, but It's dead-simple to use, solde...
#guide #setup #circuit playground
