Let's do some creative projects to get familiar with the GlowBit™ rainbow and micro:bit. The animation runs for 10 seconds, and can be started by pressing either of the micro:bit's buttons
In this guide we will:
- Wire a rainbow to a micro:bit,
- Upload an example program to make sure everything works, and
- Create several interesting projects from scratch!
To follow along, you'll need:
- 1x micro:bit with USB cable - the micro:bit GO kit is a great way to get started.
- 1x GlowBit rainbow
- 3x Alligator test leads. I'll be using Red, Black and Yellow. If you already have some Banana leads, those will work too.
- A battery pack for your micro:bit will allow you to drive your rainbow to maximum brightness. If you don't have a battery pack, that's ok too. If your rainbow flickers, that could be an indicator you're drawing too much power for the micro:bit to output. Try your experiment again at lower brightness.
Let's get started!
Getting Started
- Project 1: Tilt-o-meter (MicroPython)
- Project 2: Marquee display (MicroPython)
- Project 3: Mood Lamp (MicroPython)
- Project 4: Skill Game (MicroPython)
- Project 5: Pair of Dice (MicroPython)
- Project 6: Electronic Compass (MicroPython)
- Project 7: Comet Tail: Multi-Rainbow project (MicroPython)
- Remix: Animate a Beautiful Rainbow: (MicroPython)
It's best to unpower your micro:bit when wiring - make sure the USB lead or any batteries are disconnected for this bit.
- Use the Black alligator clips to connect GND on the micro:bit to GND on the rainbow
- Use the Red alligator clips to connect 3V on the micro:bit to 3V on the rainbow
- Use the Yellow alligator clips to connect 0 on the micro:bit to Data on the rainbow
Wiring diagram for connecting a micro:bit to a GlowBit rainbow
Upload a Code Example
Time to make sure everything works, we'll upload a test pattern to the micro:bit.
- Open this test program
- Click the Download button
- Connect your micro:bit to your computer with a USB cable
- copy the program onto your micro:bit
Once the program is uploaded, your rainbow should look like... a rainbow!
If you're having trouble with this step, take a picture of your setup and open a thread in our forums - we're full-time maker's and are here to help!
Project 1: Tilt-o-meter (makecode)
Let's code a project that measures the tilt-angle of the micro:bit, and displays it on the rainbow by lighting up a corresponding LED. Since we're already wired up, all we need to do is reprogram the micro:bit. If you really want to skip ahead, the code for this project is linked here, but I've always found doing code-alongs to be more fruitful.
Step 1 - Setup & Measure
Create a new project. First, on start we'll initialise the rainbow as a strip of 13 NeoPixels. Then, in forever we'll begin by clearing the strip, and measure the micro:bit's roll angle - store that in a variable called roll.
Step 2 - Map
Next, we will convert the roll-angle into an index for which LED to illuminate. Roll is zero when the micro:bit is level. As the micro:bit tilts left or right, the roll angle is negative or positive. A quarter turn in either direction is 90 degrees, so we can map the range -90 to 90 degrees into an LED number (0 to 12). We'll store the result in a variable called gauge. Map will return floating point numbers, but we need the gauge variable to be a whole number - set gauge to the rounded value of itself.
Step 3 - Dazzle
Finally, all that's left is to send the data with the NeoPixel: set pixel color command and show the data. Since we clear the rainbow at the top of the forever loop, this code will only ever illuminate one LED at a time.
That's all there is to it! Upload the new code to your micro:bit and experiment with rolling the microbit.
Step 4 - Remix
There's a few interesting observations we can make! What happens if we...
- Fix the rainbow to a table and roll the micro:bit?
- Roll the rainbow with the micro:bit?
- Flip the rainbow around and then roll the rainbow with the micro:bit?
Project 2: Marquee Display
Marquee lights are fancy, eye-catching lighting displays used by cinemas, theatres and shops. We're going to program our rainbow with an animated marquee pattern - lighting every third LED and giving the illusion of movement.
We'll program in micropython for this project, head over to python.microbit.org to get started. Code along with this project video - if you get stuck, you can copy the working code below.
# Create a marquee light animation using simple math tricks from microbit import * import neopixel # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 rainbow = neopixel.NeoPixel(pin0, 13) violet = (60, 33, 60) counter = 0 while True: rainbow.clear() for i in range(13): if (i - counter) % 3 == 0: # true for every third LED rainbow[i] = violet rainbow.show() counter = counter + 1 sleep(200)
Create a moody-display that's different every time - use random numbers to generate a new unique colour
# Make a mood lamp with the GlowBit Rainbow # Press either button to step through random colours from microbit import * import neopixel from random import randint # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 rainbow = neopixel.NeoPixel(pin0, 13) while True: if button_a.was_pressed() or button_b.was_pressed(): red = randint(0, 60) green = randint(0, 60) blue = randint(0, 60) for i in range(13): # Assign the current LED a random red, green and blue value between 0 and 60 rainbow[i] = (red, green, blue) # Display the current pixel data on the Neopixel strip rainbow.show() sleep(100)
Put your reaction time to the test with this skill-game - press the button only when the middle LED is lit to increase your score.
# Press button B when the middle LED is lit # the game gets harder the more points you score from microbit import * import neopixel from random import randint # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 rainbow = neopixel.NeoPixel(pin0, 13) # game variables active = 0 # which LED is active direction = 1 # the direction to move score = 0 # current score # game colour changes every game red = randint(0, 60) green = randint(0, 60) blue = randint(0, 60) while True: # Update the game display rainbow.clear() rainbow[active] = (red, green, blue) rainbow.show() sleep(400 - score) if button_b.was_pressed(): if active == 6: # LED 6 is the middle LED score = score + 25 # increment the score else: # LOSE print("Scored {} points".format(score)) sleep(1000) reset() # Update the game state - move the LED and bounce off the ends active = active + direction if active >= 12: direction = -1 elif active <= 0: direction = 1
Create a pair of virtual dice to add some colour to your games-night.
# Make a set of electronic dice # Create two independent, six-sided dice from microbit import * import neopixel from random import randint # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 rainbow = neopixel.NeoPixel(pin0, 13) orange = (51, 33, 0) fuchsia = (51, 0, 51) while True: if button_a.was_pressed(): # roll the left die value = randint(0, 5) for i in range (0, 6): if i <= value: rainbow[i] = orange else: rainbow[i] = (0,0,0) rainbow.show() if button_b.was_pressed(): # roll the right die value = randint(7, 12) for i in range (7, 13): if i >= value: rainbow[i] = fuchsia else: rainbow[i] = (0,0,0) rainbow.show()
Get your bearings with an electronic compass! We'll read the heading from the micro:bit's magnetometer and use our rainbow to indicate the direction of magnetic North.
# Make an electronic compass using the micro:bits magnetometer and a GlowBit Rainbow from microbit import * import neopixel from random import randint # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 rainbow = neopixel.NeoPixel(pin0, 13) # A function to convert from one range of numbers to another # Useful to convert FROM 0-360degrees TO LED no. 0-12 def convert(x, i_m, i_M, o_m, o_M): return max(min(o_M, (x - i_m) * (o_M - o_m) // (i_M - i_m)), o_m) while True: rainbow.clear() # convert 0-360 degrees to -180 to 180 degrees heading = compass.heading() if heading > 180 and heading <= 360: heading = heading - 360 # convert (-90 to 90) degrees to LED number (0 to 12) index = convert(heading,90,-90,0,12) print(str(heading) + " " + str(index)) index = round(index) # round to nearest whole number rainbow[index] = (30,0,0) rainbow.show() sleep(100)
Project 7: Comet Tail: Multi-Rainbow Project
Did you know you can connect multiple rainbows together to create a longer strip of GlowBits? In this project we wire two rainbows together and create an animation that moves across them
# A bright comet flies across two rainbows from microbit import * import neopixel # Set up the rainbows (2x rainbows = 26 LEDs) numLeds = 26 rainbow = neopixel.NeoPixel(pin0, numLeds) headBrightness = 60 frame = 0 while True: val = headBrightness for i in range(0, numLeds): rainbow[ (i frame) % numLeds ] = (val, 0, 0) val = round(val * 0.75) # the next LED is dimmer if val <= 1: # 'clip' low values val = 0 frame = frame - 1 rainbow.show() sleep(50)
You may have to clip the lower brightness to zero. In the video we check
val = round(val * 0.75) if val == 1: val = 0
but a more robust check would be this, which is provided in the full example above
val = round(val * 0.75) if val <= 1: val = 0
Animation Remix: Animate a Colourful Rainbow
This code remix uses ideas we've already explored in this tutorial (colour-wheel, animation) and brings them together to create a beautiful, multicoloured rainbow.
# Animate a beautiful, multicoloured rainbow # Press the A or B button to begin! from microbit import * import neopixel from utime import ticks_diff, ticks_ms # Python colour wheel - returns R,G,B values based on an input from 0-255 def wheel(pos): # The colours transition through r - g - b - back to r. if pos < 0 or pos > 255: return (0, 0, 0) if pos < 85: return (255 - pos * 3, pos * 3, 0) if pos < 170: pos -= 85 return (0, 255 - pos * 3, pos * 3) pos -= 170 return (pos * 3, 0, 255 - pos * 3) # Set brightness based on a value from 0 to 100 def adjust_rainbow_brightness(brightness): if brightness > 100: brightness = 100 if brightness < 0: brightness = 0 brightness = brightness / 100 for i in range(13): (r,g,b) = rainbow[i] r = int(r * brightness) g = int(g * brightness) b = int(b * brightness) rainbow[i] = (r,g,b) # Clear the rainbow (turn off each LED) def clear_rainbow(): for i in range(13): rainbow[i] = (0,0,0) rainbow.show() # Setup the Rainbow as a Neopixel strip on pin0 with a length of 13 num_LEDs = 13 rainbow = neopixel.NeoPixel(pin0, num_LEDs) clear_rainbow() frame = 0 # used to drive the animation. # and now for our main loop while True: # wait for a/b button press if button_a.was_pressed() or button_b.was_pressed(): # Get the animation start-time start_time = ticks_ms() # Show a rotating rainbow and stop after 10 seconds while ticks_diff(ticks_ms(), start_time) < 10000: for i in range(13): # for each LED hue = int(frame + (i * 255 / num_LEDs)) # get a unique hue for this LED. i is the LED number, and frame changes the colour over time if hue > 255: hue = hue-255 # Wrap hue back to zero if it goes above 255 rainbow[i] = wheel(hue) # convert hue to RGB and apply to this LED adjust_rainbow_brightness(20) # scale the brightness. Default is *really* bright rainbow.show() frame += 1 # increment the animation by one "frame". Larger steps make for a faster scrolling pattern sleep(10) # rainbow complete! clear the LEDs and wait for another button press clear_rainbow()
