The Rigol DP-832 is a 3-channel, benchtop power supply suitable for a serious maker, makerspace or product developer.
In this video I'll take you on a tour of the supply's operation and give my two cents on things I like and dislike.
Key Specifications | |
Voltage Range | CH1 & 2: 0-30V CH3: 0-5V |
Current Range | 0-3A all channels |
Load Regulation Rate ± (Output Percentage + Offset) | |
Voltage | <0.01% + 2mv |
Current | <0.01% + 250μA |
Linear Regulation Rate ± (Output Percentage + Offset) | |
Ripple (20Hz to 20Mhz) | |
Normal Mode Voltage | <350μVrms / 2mVpp |
Normal Mode Current | <2mArms |
