I have a new phone and want the battery health to last as long as possible. Charging it to 100% overnight, every night, may reduce the battery capacity over time so I have been looking for a solution to help me to protect the battery.
Android does not offer a way to control the charging directly so I needed a solution external to the phone.
Build a solution to shut off the phone charger when it reaches a certain percentage by using a Raspberry Pi and a relay.
You can see the final board layout in a simple case on the second tab. Note that this is an original Raspberry Pi 1B, but the solution is likely to work with any Pi.
Raspberry Pi (I used a 1B but any Pi should do, or even a Pico!)
USB Cable (to solder)
10 Watt USB Powered Qi Charging Pad (mine came from officeworks)
An Android Phone (this guide uses an app called automate, I'm unsure of an iOS equivalent)
The solution works in two parts.
Firstly, I created a script that uses the Android Automate app ( a free app from llamalab).
The script performs the following steps:
Check if I am connected to my home WiFi
Check if the phone is currently being charged
If the battery level is over 85%, send an HTTP request to my Raspberry Pi
Secondly, I created a tiny web server running on a Raspberry Pi.
If this web server receives any request, it switches a relay to turn off the power to the phone charger. This is such a small script it would likely work on a Raspberry Pi Pico too!
#!/usr/bin/python # Script to stop phone charging when an http request is received # To stop the phone charging a relay is connected to a raspberry pi GPIO pin # JKenyon 2024 # Libraries import RPi.GPIO as GPIO from time import sleep import socket # Define constants SERVER_HOST = '0.0.0.0' SERVER_PORT = 8001 RELAY_PIN = 24 SLEEP_TIME = 5*60*60 # 5 hours # Define a simple web server that quits after it receives a connection def waitForConnection(): # https://www.codementor.io/@joaojonesventura/building-a-basic-http-server-from-scratch-in-python-1cedkg0842 # Modified to exit when a connection is made # Create socket server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM) server_socket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1) server_socket.bind((SERVER_HOST, SERVER_PORT)) server_socket.listen(1) # Wait until we receive any connection (as we don’t parse anything this is pretty safe) client_connection, client_address = server_socket.accept() response = 'HTTP/1.0 200 OK\n\n' client_connection.sendall(response.encode()) client_connection.close() # Close socket server_socket.close() # Define a function to control the GPIO and switch off the charger def switchOffChargerForTime(delay): GPIO.setmode(GPIO.BCM) GPIO.setup(RELAY_PIN, 0) sleep(delay) GPIO.setup(RELAY_PIN, 1) GPIO.cleanup() while True: waitForConnection() switchOffChargerForTime(SLEEP_TIME)
The GPIO code is not necessarily the perfect way to control a relay. I chose to do it this way as the relay I have was not switching reliably at 3.3V. If you have a relay that is better behaved then you can change the power to the relay module to pin 1 (to supply 3.3V) and use GPIO.output(RELAY_PIN, GPIO.HIGH) and GPIO.output(RELAY_PIN, GPIO.LOW) to switch the relay.
The diagram in the second tab shows how everything is connected. I had originally planned to use the Raspberry Pi to supply the 5V to the charger, but this was a bit too much so I settled on using a separate power supply.
