Automating Test-Equipment with Python
The full example-code is reproduced at the bottom of this article. Performing manual measurements (in bulk) is for suckers and undergraduate students. Thankfully, most lab gear comes with a digital interface like USB or Serial and you can ...
#oscilloscope #power supply #multimeter #measure #python #script #lab #test
How to Update Firmware on Rigol Oscilloscopes
This tutorial will show you how to update the software on your Rigol Oscilloscope. This will unlock the latest features as well as solve some bugs. What you will need. Rigol Digital OscilloScope (1054Z or 1104Z) USB thumb drive (any wi...
#oscilloscope #rigol #firmware
In this article I'll compare three popular Arbitrary function generators. They are all about the same price point and popular among makers. The models up for review are: Rigol DG1022          (data) ...
Our Siglent SDG1032X Arbitrary Function Generator Review
Let's take a look at the new Siglent SDG1032X Arbitrary function generator. We're looking at yet another example of the closing gap between hobbyist and pro gear - the growing feature set and capabilities of entry-level equipment continues ...
#function #generator #review #siglent
Our Rigol DS1052E Oscilloscope Review
The 2-channel Rigol DS1052E oscilloscope is beloved by many as a really decent, cheap 'scope for the home electronics lab. While its features pale next to those hosted by more modern offerings, the 1052 packs the basics into a reliable...
Our Rigol DS1104Z Oscilloscope Review
The 4-channel Rigol DS1104Z oscilloscope is a 100MHz powerhouse. The DS1104Z is almost identical to its little brother, the DS1054Z, but brings to the table twice the bandwidth. The 1000Z line of oscilloscopes from Rigol is one...
#oscilloscope #rigol #review
Our Rigol DS1054Z Oscilloscope Review
The quality and features in entry-level 'scopes has made a huge jump in recent years - In a nutshell, the 4-channel Rigol DS1054Z oscilloscope delivers tremendous bang for your buck.  The DS1054Z is so well outfitted, I'd b...
The Rigol DP-832 is a 3-channel, benchtop power supply suitable for a serious maker, makerspace or product developer. In this video I'll take you on a tour of the supply's operation and give my two cents on things I like and dislike. ...
Our Mooshimeter Review
We've been familiar with the Mooshimeter for a while now, we've got tutorials on Getting up and running with a Mooshimeter, how to datalog with your mooshimeter, taking voltage/current measurements with multi-meters and finally a whole arti...
#review #mooshimeter
Tips for Mooshimeter Maitenance
Now that you have picked up your Mooshimeter, there might be a few questions you have on keeping it working well for as long as possible. As the Mooshimeter is a battery powered device, eventually the day will come where you simply cannot c...
#multimeter #mooshimeter #battery replacement #fuse #shipping mode
How to use a Digital Multimeter
A digital multimeter (DMM) is one of the most common tools on a Maker's bench. We use DMMs to take electrical measurements in a fast and relatively accurate way. The reason we call it a multimeter is because they can take multiple types mea...
#current #multimeter #measurements #resistance #voltage
How to log measurements using a Mooshimeter
The Mooshimeter is one of our favorite multimeters here at Core Electronics! If you haven't heard about them before, then take a quick look at our review. One of the most popular features of the Mooshimeter is the ability to log voltag...
#multimeter #ble #data logging #mooshimeter
Join the new age with a Mooshimeter
The multimeter is one of the essential tools in your electronics toolkit. These battery operated devices combine several measurement functions into one easy to use device. You can get Analog or Digital multimeters, each displaying your meas...
#tools #dmm #measurement #multimeter
Getting Started with Saleae: Tips and Tricks
Well hello there, if you’ve been looking at the amazing line-up of Saleae gear and wondered how to get started with it all, then you’ve come to the right place. Today we’re going to take a look at getting your Saleae setup...
#digital #analyser #logic #saleae
Choosing a Benchtop Power Supply
If you're looking for a benchtop power supply, but you're unsure of what you should be looking for in a decent supply for your workspace, we have got you covered with this guide. We will look at the specifications to look out for in a power...
#guide #benchtop #equipment #laboratory #power #supply
Saleae Models Compared
Logic analysers are an incredibly valuable piece of test and measuring equipment, but sometimes it can be hard to work out exactly what you need, and what model is going to best suit your needs. If you’re not sure what a logic analyse...
What is a Logic Analyser
If you’ve ever come across the term ‘logic analyser’ and not been sure exactly what is was, you’re in the right place. Logic analysers are one of the less common pieces of test and measuring equipment, but they&rsquo...
Rigol's PC software: Ultra-Sigma and beyond
The ability to connect your test equipment to a local PC is invaluable. It allows monitoring and the use of your equipment via a PC interface. That includes coveted mouse/keyboard control! This control centre capability is essential when yo...
#rigol #connection #pc #usb
Using your Arbitrary Waveform Generator
By now you are aware that when it comes to measuring electronic signals, oscilloscopes are what you are going to be using. However, if you were providing a circuit with a particular signal, a function generator is the perfect tool for tha...
#arbitrary #function #generator #waveform
Oscilloscope Triggers: A quick what and how
So we have vertical graphing of voltage and horizontal sweep, but our signal is just going to go bananas on our screen if we don't sweep at the same point in the waveform. That's where triggers come in, allowing us multiple ways to fix ou...
#dso #oscilloscope #operation #triggers
Our Recommendation for your first Benchtop Oscilloscope
You’ve been working on that project for days, even weeks, and you’ve gone through all the steps of the process; meticulously ensuring everything is above board. And yet, for some unexplainable reason, your circuit is acting out....
#beginner #oscilloscope #tools
