- Raspberry Pi Generations Table 1 - Speed Specs
- Raspberry Pi Generations Table 2 - Connectivity Specs
- Connectivity and Computing Infrastructure Locations for All Boards
The company launched in 2012 the Raspberry Pi is now on the eighth year of iteration. As the company has grown they have produced a number of different microprocessors all under the Raspberry Pi name. Now you can buy an impressive selection of different versions and models of the Raspberry Pi. We have simplified most of the common features and specifications below. Thus you can decide which version of Raspberry Pi board best suits your maker project. Raspberry Pi name their boards based on the generation and on the form-factor / footprint of the board. The current generations of Regular Raspberry Pi boards are Zero, 1, 2, 3 and 4. The original Raspberry 1 had 4 different options: Model A, Model A +, Model B, and Model B +. The B models are the original credit-card sized format. Whereas the current A models have a smaller and more compact footprint, this often means they have reduced connectivity options. Zero models are the most compact of all the Raspberry Boards types and this affects their connectivity. Zero models also come with or without GPIO headers installed.
According to legend the name Raspberry Pi was chosen with Raspberry as an ode to a tradition of naming early computer companies after fruit, and Pi as a reference to the Python programming language. As always if you have any questions, queries or things to add please let us know your thoughts!
Below is a table that will get you up to speed with all computational specifications to do with any model in any generations of the Raspberry Pi up to today. If your holding one in your hands and have not figured out which one it is or what hardware it has this is the table for you. The have loosely been ordered by the release date. Further details on the location of both computing infrastructure and connectivity can be seen in the final section.
Details about each Raspberry Pi Board can be seen in the below table with a particular emphasis on the connectivity types available to each. They have been loosely ordered by release date, same as above table. Further details on the location of both computing infrastructure and connectivity can be seen in the next section below for all the generations of these boards.
Below is a series of diagrams showing the locations of connections and main integrated circuits for almost all the Raspberry Pi boards. The first four Raspberry Pi boards will be the Model B, then two version of the Model A boards and finally Raspberry Pi Zero boards. A big difference between the most current Models are the dimensions/footprint of the microprocessors.
