PiicoDev Ambient Light Sensor VEML6030 - Raspberry Pi Guide
Updated 17 September 2021
This guide will help you read light intensity data from your PiicoDev® Ambient Light Sensor and a Raspberry Pi single-board computer
In the video we use a PiicoDev Platform to keep everything safe and secure.
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Light Sensor to the Adapter via the PiicoDev cable.
connect-piicodev-light-sensor-to-raspberry-pi
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the light sensor with a PiicoDev Cable.
Enable I2C
raspberry-pi-enable-i2c
Install PiicoDev
Download the Example Script
Download this example script: main.py (right-click, "save link as")
Save this file wherever you like to keep your programming projects. For this tutorial I'll save mine in /home/pi/PiicoDev and change the name to light.py to give it some context.
Run the Example
example-piicodev-ambient-light-sensor-veml6030-raspberry-pi
Pictured above: The light data streams up the Shell and graphs in the Plotter (View > Show Plotter). The measured light starts at about 200 lux (ambient, office) increases when I shine a light on it, and falls off to about zero when I cover the sensor with my hand.
All going well, light data will begin streaming up the Shell window.
pi raspberry sensor light piicodev
