Let's get started with the PiicoDev® OLED Module SSD1306. In this guide, we'll connect the PiicoDev OLED to our Raspberry Pi Pico and get it working with some example code to display text, shapes, and animations.
- A Micro:bit V2
- A PiicoDev OLED Module SSD1306
- A PiicoDev Adapter for Micro:bit
- A PiicoDev Cable
- Connect the OLED to your Micro:bit
- Line
- Rectangle
- Text
- Graph
- Animation
- Bitmap Images
- Remix - Graph distance
- Remix - Tilt Table
- Conclusion
Connect the PiicoDev OLED Module to your Micro:bit
First, make sure your OLED is set to the correct address. Referring to the image below: For modules with an address jumper (labelled "ADDR"), this jumper should be unconnected - as shown on the left. For modules with an address switch (labelled "ASW"), this switch should be in the OFF position - as shown on the right.
Plug your Micro:bit into the adapter, connect your OLED to the adapter via the PiicoDev cable, and finally connect your Micro:bit to your computer with a USB lead.
Download MicroPython modules
We will need some drivers to easily work with the OLED module:
- Download the device module: PiicoDev_SSD1306.py (right-click, "save link as")
- Download the font file font-pet-me-128.dat (right-click, "save link as")
Line
- line(x1, y1, x2, y2, c) will draw a two-point line from (x1,y1) to (x2,y2) of colour c.
- hline(x, y, l, c) will draw a horizontal line from (x, y) of length l, colour c. Always draws left-to-right.
- vline(x, y, l, c) is similar to hline, but draws vertical lines.
The following example draws horizontal and vertical lines from the same point and joins their ends with a two-point line. There is a small delay between the drawing of each line.
from PiicoDev_SSD1306 import * from PiicoDev_Unified import sleep_ms # cross-platform compatible sleep function display = create_PiicoDev_SSD1306() display.hline(10,10, 80, 1) # horizontal line 80px long from (10,10) display.show() sleep_ms(500) display.vline(10,10, 35, 1) # vertical line 35px long from (10,10) display.show() sleep_ms(500) display.line(10,45, 90,10, 1) # two-point line from (10,45) to (90,10) display.show() sleep_ms(500)
Rectangle
The top-left corner is specified by (x,y) and width and height set the width and height in pixels. colour sets the line colour with white=1 and black=0
The following example draws an unfilled rectangle to the left of the display, and a filled white rectangle to the right. A filled black rectangle is then drawn over the top.
from PiicoDev_SSD1306 import * display = create_PiicoDev_SSD1306() display.rect(10, 10, 20, 50, 1) # unfilled rectangle display.fill_rect(50, 10, 50, 40, 1) # filled rectangle (white) display.fill_rect(60, 20, 30, 20, 0) # filled rectangle (black) display.show()
The rect function was used in the first feature demonstration to make two bargraphs - the width of each rectangle is updated by a variable that changes over time.
Filled rectangles can take a long time to display when using Micro:bit. In general, an unfilled rectangle is much faster.
Text
Display alphanumeric text with text(string, x, y, colour), where;
- string is a python string
- x, y are the top-left co-ordinates
- colour is 1 (white) or 0 (black)
The following example prints four lines. The first is a literal string, where the text to be printed is inserted into the function call. The second prints a string variable myString. The third and fourth print the value stored in a variable.
myString = "this is me"
myNumber = 123.4567
display.text("Hello, World!", 0,0, 1) # literal string
display.text(myString, 0,15, 1) # string variable
display.text(str(myNumber), 0,30, 1) # print a variable
display.text("{:.2f}".format(myNumber), 0,45, 1) # use formatted-print
display.show()
Graph
updateGraph2D(graph, value) pushes the latest value onto a graph object. Multiple graphs can be shown at the same time and must be updated by making separate calls to updateGraph2D().
The following example graphs two functions independently.
from math import sin, cos, pi
graph1 = display.graph2D(minValue=-1, maxValue=1) # create two graph2D objects
graph2 = display.graph2D(minValue=-4, maxValue=4)
for x in range(WIDTH):
y = sin(2*pi*x/WIDTH) # sine wave with amplitude 1, and wavelength equal to the screen width
z = 2*cos(6*pi*x/WIDTH) # cosine wave with amplitude 2, and wavelength one-third the screen width
display.fill(0)
display.updateGraph2D(graph1, y)
display.updateGraph2D(graph2, z)
display.hline(0,int(HEIGHT/2),128,1) # draw a zero-axis
display.show()
Each graph is initialised with different max- and minValues which allow them to be scaled independently. Even though the high-frequency cosine function has a larger amplitude (2), it appears smaller on the graph because graph2 is initialised with a larger range between minValue and maxValue.
By default, a graph fills the whole display. See the PiicoDev documentation for other setup options.
Animation
This is where things get a lot more freestyle! An animation is created by drawing frames with each new frame changing a small amount. To animate a square moving around the screen, we just need to change the (x,y) location of that square by a small amount every frame. We can take advantage of some mathematical tricks to create smooth motion. The following example uses a single variable (theta) to move a square in a smooth, circular path. We can do this by converting the polar coordinates (radius, theta) into cartesian coordinates (x, y). By incrementing theta a small amount in each loop, we change the location on the circle that the rectangle will be drawn. Do this repeatedly and it looks like the square is moving smoothly.
In general, the steps to create an animation are:
- Clear the display (we generally don't want to draw over old frames)
- Draw a frame - this is usually generated by some variable that changes with time; like a frame counter, or in this case, the angle "theta".
- Update the display
# Circular path animation
r = 20 # radius of the path (px)
theta = 0
### Clear the display ###
display.fill(0)
### Draw a frame ###
theta = theta + 0.02 # increment theta by a small amount
# convert polar coordinates (r, theta) to cartesian coordinates (x, y)
x = WIDTH/2 + r * cos(theta)
y = HEIGHT/2 + r * sin(theta)
display.fill_rect(round(x), round(y), 10, 10, 1)
# display.line(round(WIDTH/2)+5, round(HEIGHT/2)+5, round(x+5), round(y+5), 1) # uncomment for a bonus!
### Update display ###
display.show()
# sleep_ms(10) # sleep optional. Updating the display takes long enough
Of course, this is just one example of animation. Try playing with some of the parameters and observing how they change the motion path.
Bitmap Images
Before running the following example, download the PiicoDev Test Image and upload it to your Pico.
# Display a portable bitmap image (.pbm)
display.load_pbm('piicodev-logo.pbm', 1)
display.show()
There are free online tools available to convert your own images to .pbm - it's best if your image size is already 128x64 pixels.
Since images are loaded into the frame buffer like any other drawing, you can still draw over the top of them if you want.
Remix - Graph Distance
It's time to get creative! This remix uses a PiicoDev Distance Sensor as an interactive input. It reads the distance from the sensor in millimetres and plots the result to the OLED module. To follow along you will of course need this sensor, and to upload the device driver to your Micro:bit: PiicoDev_VL53L1X.py (right-click, save-as). Read the PiicoDev Distance Sensor Guide for more help.
# Sample distance with a PiicoDev Distance Sensor and plot the data on a PiicoDev OLED
# Initialise distance sensor and display
distanceGraph = display.graph2D(height=HEIGHT-10, minValue=0, maxValue=500) # Initialise graph with scale 0 -> 500mm
display.fill(0) # we need to clear the display every frame
display.hline(0,HEIGHT-1,WIDTH,1); display.vline(0,0,HEIGHT,1) # draw some axes
dist_mm = distSensor.read() # read the distance in millimetres
display.text(str(dist_mm),95,3,1) # print the distance in the top right
display.updateGraph2D(distanceGraph, dist_mm) # plot the distance
display.show() # don't forget to show()!
Notice in this remix we're using some extra arguments in graph2D(). The height argument sets the maximum vertical size of our graph area. By making the graph area smaller than the maximum size, we can guarantee the displayed text is never drawn over. We also use the minValue and maxValue arguments to set the vertical scale of our graph to 0-500mm. It's the minValue and maxValue arguments that are most useful if you'd like to use this remix to plot data from any other sensor.
Remix - Tilt Table
In this remix, we'll use the PiicoDev Motion Sensor to change the location of a square shown on the display. As we tilt the motion sensor, the square will move in the corresponding direction. To follow along you'll need the Motion Sensor and to upload the device driver to your Pico: PiicoDev_MPU6050.py (right-click, save-as). Read the PiicoDev Motion Sensor Guide for more help.
# Draw a square to indicate the tilt angle of an IMU - requires a PiicoDev Motion Sensor
from PiicoDev_MPU6050 import PiicoDev_MPU6050
display = create_PiicoDev_SSD1306() # initialise PiicoDev modules
motion = PiicoDev_MPU6050()
display.fill(0) # clear the screen every frame
tilt = motion.read_angle() # read the angle (radians)
aX = tilt['x']
aY = tilt['y']
sensitivity = 50 # sets how far the square will move for a given tilt
x = round( aY * sensitivity + WIDTH/2)
y = round( aX * sensitivity + HEIGHT/2) # convert angles to x,y coordinates for the square
print("{:.2f} {:.2f}".format(aX , aY))
display.rect(x-5,y-5,10,10,1) # draw the square
display.show()
We've really taken our PiicoDev OLED module for a test-drive! From simple text, shapes and lines through to animations and even complex images - the sky is the limit! We even brought some other sensors in the mix to run some creative coding remixes. If you make anything cool from these examples - or just have some questions, be sure to leave a comment on this article. We're full-time makers and here to help!
