One of the most common sensors in any makers toolbox is the HC-SR04 Ultrasonic Rangefinder. They are an easy to use solution for detecting the proximity of objects up to 6m away! They work best in the 1-2 meter range though. In this tutorial, we will be using the Pycom Lopy4 to take readings from an HC-SR04 Rangefinder.
How it works
The ultrasonic rangefinder works by sending out a 10us pulse of sound at 40,000hz. The sound bounces off an object and travels back to the sensor. The length of the received echo is proportional to the distance that the sound travelled. We can measure the length of the return pulse and calculate the distance. Using the formula:
Time = Distance / Speed
The time is measured in microseconds with the sensor, and we know the speed of sound is 340m/s or .034cm/us. We then need to divide the result by 2 because the distance will be how far the pulse travelled there and back. The final formula is:
Distance = (Time(us) * .034) / 2
The Circuit
The HC-SR04 is a 5V device, and Pycom boards are all 3.3V. We can power the sensor using the VIN pin on the expansion board ONLY if we are connected to USB. If we are running on batteries then we won't have the 5V needed and will need to power the sensor using a regulator or a separate 5V source. The 3.3V logic from the Pycom boards works to trigger the sensor.
We also need to step down the echo voltage from 5V to 3.3V. We've done this by using a voltage divider. We had 1k resistors handy but you could use a 1k and a 2.2k resistor instead.
Despite its apparent complexity, the HC-SR04 is an analog sensor. This means that the measurements made using this sensor need to be controlled on the microcontroller. In this example, we will be using the Pycom Lopy4 to take readings and then upload the results to The Things Network. You could use this code with any Pycom board, just leave out the LoRa parts!
Taking Measurements
This code is the bare bones needed to take distance measurements using the HC-SR04 Ultrasonic Rangefinder. We will be using the utime library because there is a function in it that will be unaffected by the clock rolling over. We initialize the echo and trigger pin that we are connecting the sensor to. In this example, we are using the Expansion board, if you are connecting directly to your Pycom board then use the relevant pin on the board itself. Just refer to the Pinout Diagram to find its number.
import utime
import pycom
import machine
from machine import Pin
# initialise Ultrasonic Sensor pins
echo = Pin(Pin.exp_board.G7, mode=Pin.IN) # Lopy4 specific: Pin('P20', mode=Pin.IN)
trigger = Pin(Pin.exp_board.G8, mode=Pin.OUT) # Lopy4 specific Pin('P21', mode=Pin.IN)
trigger(0)
# Ultrasonic distance measurment
def distance_measure():
# trigger pulse LOW for 2us (just in case)
trigger(0)
utime.sleep_us(2)
# trigger HIGH for a 10us pulse
trigger(1)
utime.sleep_us(10)
trigger(0)
# wait for the rising edge of the echo then start timer
while echo() == 0:
pass
start = utime.ticks_us()
# wait for end of echo pulse then stop timer
while echo() == 1:
pass
finish = utime.ticks_us()
# pause for 20ms to prevent overlapping echos
utime.sleep_ms(20)
# calculate distance by using time difference between start and stop
# speed of sound 340m/s or .034cm/us. Time * .034cm/us = Distance sound travelled there and back
# divide by two for distance to object detected.
distance = ((utime.ticks_diff(start, finish)) * .034)/2
return distance
print(distance_measure())
Eliminating False Readings
One of the limitations to using an ultrasonic rangefinder is the ever-broadening detection area as the sound moves away from the sensor. As objects move farther away it is more likely that sound will bounce back from other objects, or environmental noise will affect your readings. We need a way to eliminate those errors from our readings. To do this we will take ten reading in rapid succession, and then keep the median reading. This eliminates any outlier readings and makes it much more likely that your reading will be accurate. The more samples you take the more accurate your reading will become, but at the cost of time. If you are trying to measure a fast moving object you should only take the median from five samples.
# to reduce errors we take ten readings and use the median
def distance_median():
# initialise the list
distance_samples = []
# take 10 samples and append them into the list
for count in range(10):
distance_samples.append(int(distance_measure()))
# sort the list
distance_samples = sorted(distance_samples)
# take the center list row value (median average)
distance_median = distance_samples[int(len(distance_samples)/2)]
# apply the function to scale to volts
print(distance_samples)
return int(distance_median)
The Big Picture
Now that we have the basics down, we will add in everything we need to get the ultrasonic sensor sending data to The Things Network via LoRaWAN!
from network import LoRa
import socket
import utime
import binascii
import pycom
import ustruct
import machine
trigger(0)
trigger(0)
utime.sleep_us(2)
trigger(1)
utime.sleep_us(10)
trigger(0)
while echo() == 0:
pass
while echo() == 1:
pass
utime.sleep_ms(20)
return distance
# sort the list
pycom.heartbeat(False)
# set LED to red
pycom.rgbled(0x7f0000)
# lora config
# access info
app_eui = binascii.unhexlify('70B3D57ED0012FC2')
app_key = binascii.unhexlify('6C3B6BD79C939C85AF19786EA4120057')
# wait for a connection
while not lora.has_joined():
utime.sleep(1)
if utime.time() > 15:
print("possible timeout")
machine.reset()
pass
pycom.rgbled(0x004600)
print('Network joined!')
# setup the socket
s.setblocking(False)
s.bind(1)
count = 0
while count < 200:
# take distance measurment, turn the light blue when measuring
pycom.rgbled(0x00007d)
utime.sleep(1)
distance = distance_median()
print("Distance: ", distance)
# could be extended like this struct.pack('f', distance) + struct.pack('c',"example text")
# 'h' packs it into a short, 'f' packs it into a float, must be decoded in TTN
packet = ustruct.pack('h', distance)
s.send(packet)
print ("Unpacked value is:", ustruct.unpack('h',packet)[0])
rx_pkt = s.recv(64)
if len(rx_pkt) > 0:
pycom.rgbled(0xffa500)
count += 1
utime.sleep(10)
Now we have data coming into the serial monitor!
The Things Network
When we run this program we will take 10 distance readings in a burst, and return the median value. That value is then encoded and sent to The Things Network as a payload. To be able to read it on TTN we will need to decode it. In the "Payload Formats" on our application page within TTN, we will use the following javascript decoder to unpack our data from bytes:
function Decoder(bytes, port) {
// Decode an uplink message from a buffer
// (array) of bytes to an object of fields.
var decoded = {};
// Decode bytes to int
var testShort = (bytes[1] << 8) | bytes[0];
// Decode int
decoded.Distance = testShort;
return decoded;
Now that our decoder is entered we should be getting human-readable data flowing in!
Going Further
In this tutorial, we demonstrated the basics of using the HC-SR04, but we didn't talk much about connecting to TTN and using LoRaWAN with the Pycom Lopy4. If you want to learn more about LoRaWAN head over to our The Things Network Tutorials. There is even a Tutorial on Encoding and Decoding Payloads for The Things Network. If you want to learn more about using Pycom Devices, check out our Pycom Tutorials!
