PiicoDev Pressure Sensor MS5637 - Raspberry Pi Pico Guide
Updated 25 January 2022
This guide will help you read barometric pressure from your PiicoDev® Pressure Sensor and a Raspberry Pi Pico
Plug your Pico into the Expansion Board, connect your pressure sensor to the Expansion Board via the PiicoDev cable, and finally connect your Pico to your computer with a USB lead.
connect-piicodev-pressure-sensor-to-raspberry-pi-pico
Download MicroPython modules
We will need three files to easily read data from the Distance Sensor:
  • Download the device module: PiicoDev_MS5637.py (right-click, "save link as")
Example Code
Open Thonny, connect to your Pico and upload the three files (that we just downloaded) to your Pico. (Hint: View the files menu with View > Files)
Restart your Pico (Keyboard shortcut, Ctrl+D) and you should be seeing your Pico printing barometric pressure measurements in hectopascal, which is equivalent to millibar - a commonly used unit for describing barometric pressure: 1hPa = 100Pa = 1mbar.
piicodev-pressure-sensor-demo-code
Above: Pressure data streams up the Shell, while the Plot shows historic data.
Remix
Did you know you can also infer altitude from air pressure? Comment out the pressure print statement and uncomment the altitude print statement. Run the script again and now the Pico will infer altitude-above-sea-level from air pressure. There can be a bit of error here since your local weather conditions will affect the reading. You can optionally pass in the local air pressure at sea level to the read_altitude() function to correct for weather effects. You can find the current air pressure at sea level for your area with an internet search.
piicodev-pressure-sensor-ms5637-altitude-measurement-remix
We can now measure air pressure from our PiicoDev Pressure Sensor, and use it to infer altitude.
