This guide will help you read distance data in millimeters from your PiicoDev® Distance Sensor and a Raspberry Pi Pico
- A PiicoDev Distance Sensor VL53L1X
- A PiicoDev Cable
Plug your Pico into the Expansion Board, connect your distance sensor to the Expansion Board via the PiicoDev cable, and finally connect your Pico to your computer with a USB lead.
Download MicroPython modules
We will need three files to easily read data from the Distance Sensor:
- Download the device module: PiicoDev_VL53L1X.py (right-click, "save link as")
Example Code
Open Thonny, connect to your Pico and upload the three files (that we just downloaded) to your Pico. (Hint: View the files menu with View > Files)
Restart your Pico (Keyboard shortcut, Ctrl+D) and you should be seeing your Pico printing the distance it reads from the distance sensor.
Above: Distance data streams up the Shell, while the Plot shows historic distance data. I move my hand back and forth in front of the sensor to create the wave pattern in the plot.
