Unlock the full potential of your Arduino projects with a wide range of sensors, from motion and temperature to light and sound, perfect for any application.
Items 26-30 of 30
  1. M5Stack Mini Scale Unit - 5kg (HX711)
    SKU: CE10061 Brand: M5Stack
    Explore M5Stack's Mini Scale Unit featuring a 5kg capacity sensor, HX711 ADC chip, and integrated MCU for precise weighing in scientific and industrial applications, with I2C communication and programmable RGB indicators.
    7 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Dec 26th
  2. Pololu Digital Distance Sensor 5cm
    SKU: POLOLU-4050 Brand: Pololu
    This small lidar-based distance sensor detects the presence of objects within 5 cm (2"). It has a single digital output that drives low when an object is ...
    21 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  3. Arduino Modulino Distance
    SKU: ABX00102 Brand: Arduino
    A compact time-of-flight proximity sensor to accurately measure distances.
    Available with 10 to 14 day lead time
  4. Arduino Modulino Thermo
    SKU: ABX00103 Brand: Arduino
    Measure temperature and humidity for environmental monitoring, indoor climate control, and many IoT applications!
  5. Arduino Nicla Sense Env
    SKU: ABX00089 Brand: Arduino
    Integrate air-quality monitoring into your Portenta or MKR projects, with ultra-low power sensors for both indoor and outdoor environments.
    $73.95 AUD, inc GST
Take a look at our Arduino Tutorials along with our free Online Workshop. For makers, by makers.
