This guide will help you read weather data from your PiicoDev® Atmospheric Sensor and a Raspberry Pi single-board computer
- A PiicoDev Atmospheric Sensor BME280
If you prefer not to use the Expansion Board for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Atmospheric Sensor to the Adapter via the PiicoDev cable.
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the weather sensor with a PiicoDev Cable.
For sensors with an ASW switch: If your sensor has a switch labelled ASW, ensure it is in the OFF position before proceeding.
Enable I2C
Install PiicoDev
Download the Example Script
Save this file wherever you like to keep your programming projects. For this tutorial I'll save mine in /home/pi/PiicoDev
Run the Example
Pictured above: The atmospheric data streams up the Shell . From left to right, the data is Temperature (degC), Barometric Pressure (hPa) and Relative Humidity (%RH).
All going well, weather data will begin streaming up the Shell window.
Try uncommenting line 19, with another print statement involving altitude. This will print an approximate altitude difference from when the script started running - nice!
Using Multiple Sensors
It's possible to use up to two Atmospheric sensors connected together - they just need to be set up with different addresses. The default address for Atmospheric Sensors is 0x77 - If you've been following this tutorial this is the address being used by default when no address is specified. To add a second sensor, we need to change its address to 0x76, as follows.
For Sensors with an Address Switch ("ASW")
If your second sensor has an address switch (labelled "ASW"), switch it to the ON position. If your sensor does not have an ASW switch, follow these steps instead.
Use a pen, toothpick or other fine tip to make this easier. If your ASW switch is protected by a thin, orange film - carefully peel that off first before attempting to set the switch.
Two PiicoDev Atmospheric Sensors being used on the same bus - this is made possible by setting each device to a unique address. The left sensor has ASW:OFF, and the right sensor has ASW:ON.
A closeup of the switch configuration.
For Sensors with no Address Switch
If your second sensor doesn't have an address switch you'll need to (carefully!) change its address. Find the ADR jumper on the back of the sensor. Cut the trace between the centre tab and the tab labelled 0x77. Next, use solder to join the centre tab and the tab labelled 0x76.
Code
The following code will collect and print data from each Atmospheric Sensor individually. The first sensor (with address=0x77) is initialised as sensorA. The second sensor (with address=0x76) is initialised as sensorB. Once we have two sensors initialised, we can call the values() function for each to read them individually.
# PiicoDev Atmospheric Sensor BME280 - Using multiple sensors
# Connect two sensors, each with a different address. They can be initialised and read independently.
from PiicoDev_BME280 import PiicoDev_BME280
sensorA = PiicoDev_BME280() # initialise the first sensor (defaults to 0x77). This is identical to "PiicoDev_BME280(address=0x77)"
sensorB = PiicoDev_BME280(address=0x76) # initialise the second sensor at address 0x76
dataA = sensorA.values() # read all data from the first sensor
dataB = sensorB.values() # read all data from the second sensor
myString = "A: " str(dataA) " B: " str(dataB) # create output string with both data
print(myString)
sleep_ms(100)
When you run the above code, the Python Shell should print three values for A, and three values for B. These are the Temperature, Pressure and Humidity as measured by each sensor. In the first sample, we can see that sensorA reads 28.24 degrees C, while sensorB reads 28.11 degrees C.
