Here are some other tips for your uGateway:
- We recommend you update the Raspberry Zero password - we've left it as default so you can make changes without a fuss.
- There is a folder on the Raspberry Pi Desktop with service scripts inside. You can change the region by running region-select.sh (it will allow selections between AS923 and AU915, we recommend AS923 unless your TTN community is already committed to AU915).
- If you want to setup the device in your own TTN Console, then email us a reply to your order email along with the last 6 digits of your Gateway EUI (which is shown when region-select.sh is run). Also include your TTN username in the email. We’ll transfer the Gateway to your TTN account.
- The service script update.sh will run on power-up to check for updates. uGateway is already rock-solid from our testing, though we’ll use this mechanism to make updates a breeze.
To monitor statistics on your uGateway visit this URL (where "xxxxxx" are the last 6 digits of your Gateway EUI in lowercase):
http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-b827ebfffexxxxxx
For example http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-b827ebfffe08c9aa
We’re here to help – post a question in our maker forum and we’ll dive in to get you back on track!
