empowering creative people
Temperature Sensing with the TMP36 and Pycom
The TMP36 is a low cost, easy to use sensor that fits well with any project. With the TMP36, adding temperature sensing to your Pycom project is easy! In this tutorial, we will use the Pycom Lopy4, and send our measured data to The Things Network via the LoRa Network!
The Circuit
Here is a schematic for wiring up the TMP36. Keep in mind that the flat face of the sensor is facing TOWARD you in this schematic. In this example, we will be using the Pycom Expansion Board 3.0 and the Pycom Lopy4, but any Pycom board will work! If you are connecting to your Pycom board directly refer to the relevant pinout diagram.
Lopy4-expansion-board-tmp36-example
In this example, we have provided the bare minimum needed to interface with a TMP36. Get out there an integrate one into your project!
# Measuring temperature by TMP36
import machine
adc = machine.ADC()               # create an ADC object
apin = adc.channel(pin='P16')   # create an analog pin on P16 & connect TMP36
    print("")
    print("Reading TMP36 Sensor...")
    value = apin()
    print("ADC count = %d" %(value))
    # LoPy  has 1.1 V input range for ADC
    temp = ((value * 1100 ) / 4096 - 500) / 10
    print("Temperature = %5.1f C" % (temp))
    time.sleep(10)
Sending Your Readings to The Things Network
Now that you have a stable reading from the TMP36, we can package our data into bytes and send it to The Things Network. If you want to learn more about connecting your Lopy4 to The Things Network, then check out our TTN Tutorials and our Getting Started with The Things Network Tutorial. Remember to add in your own App EUI and App Key!
from network import LoRa
import socket
import utime
import binascii
import pycom
import ustruct
import machine
from machine import Pin
apin = adc.channel(pin=Pin.exp_board.G3)   # Lopy4 specific: (pin = 'P16')   create an analog pin on P16 & connect TMP36
# Temp measurment
def temp_measure():
    print("")
    value = apin()
    return temp
pycom.heartbeat(False)
# set LED to red
pycom.rgbled(0x7f0000)
# lora config
# access info
app_eui = binascii.unhexlify('XXXXXXXXXXXXXXX')
app_key = binascii.unhexlify('XXXXXXXXXXXXXXXXXXXXXXXXXXXX')
# wait for a connection
while not lora.has_joined():
	utime.sleep(1)
	if utime.time() > 15:
		print("possible timeout")
		machine.reset()
	pass
pycom.rgbled(0x004600)
print('Network joined!')
# setup the socket
s.setblocking(False)
s.bind(1)
count = 0
while count < 200:
	# take temp measurment, turn the temp blue when measuring
	pycom.rgbled(0x00007d)
	utime.sleep(1)
	temp = temp_measure()
	# could be extended like this struct.pack('f', temp) + struct.pack('c',"example text")
    # 'h' packs it into a short, 'f' packs it into a float, must be decoded in TTN
	packet = ustruct.pack('f', temp)
	s.send(packet)
	rx_pkt = s.recv(64)
	if len(rx_pkt) > 0:
		pycom.rgbled(0xffa500)
	count += 1
	utime.sleep(10)
Decoding on TTN
The above code will have you sending payloads to TTN in no time at all. To decode the payload from bytes back into user-readable data we need to enter some javascript into our Payload Formats. You can download the code for easy copy and pasting.
Javascript-decoder-screenshot
Going Further
If you want to learn more about Pycom check out our Pycom Tutorials. If you want to learn more about connecting to The Things Network and using LoRaWAN check out our The Things Network Tutorials. There are many more sensors and devices that can be used with the Pycom Lopy4, get out there and experiment!
Attachment: TTN-Decode-Float-Javascript.txt
The TMP36 is a low cost, easy to use sensor that fits well with any project. With the TMP36, adding temperature sensing to yo...
