This mini cube is made up of six 4x4 WS2812B panels giving a total of 96 individually addressable RGB LEDs. Buried inside the cube is an ATTiny85 microcontroller powered by a 120mAh Lithium-Ion battery. It also contains a mercury switch and a couple of transistors to turn the cube on. The cube switches itself off after displaying a series of animations.
All the files needed to create this project are downloadable in the ZIP file at the end of the write-up
Parts
- 6 x WS2812B 4x4 16-Bit Full Color 5050 RGB LED Lamp Panel Light
- 1 x ATTiny85 SMD
- 1 x 120mAh Lithium Ion battery
- 3 x 1M 0805 resistors
- 1 x 100K 0805 resistor
- 1 x 330R 0805 resistor
- 1 x 1K5 0805 resistor
- 2 x 0.1uF 0805 capacitors
- 1 x 100uf 10V 3528 Tantalum capacitor
- 1 x AO3401 P-Channel MOSFET SOT-23
- 1 x 2N3904 NPN Transistor SOT-23
- 1 x 0805 Red LED
- 1 x JST-PH-2-THM-RA socket
- 1 x 5mm mercury switch
Video
Assembly
3D Printing
3D print the STL holder file for the panels with supports and a raft. After you clean off the support and raft, drill out the holes with a 2.5mm drill and create a thread with a 3mm tap.
Wiring the cube
Next you need to wire up the six WS2812B panels. Start with the four side panels. I used 0.5mm tinned copper wire. Each time you complete a panel, test it on the former and re-adjust the wires if necessary to get a good fit without straining the connections and also having the screw holes lined up.
Connect fine insulated wire (I used wire-wrap wire) to the VCC, DIN, GND on the first side panel and VCC, DOUT, GND on the last side panel. Screw on the sides using M3 x 6 or M3 x 8 screws. Next connect the bottom VCC, DIN, GND to the VCC, DOUT, GND wires of the last side panel and screw it in-place.
Panel LED sequence starting from top then sides and finally bottom
For the top panel, connect the VCC, DOUT, GND to the VCC, DIN, GND wires of the first side panel. Add wires to VCC, DIN, GND of the top panel. These will ultimately be connected to the custom PCB.
Make and assemble the PCB
Eagle files have been included so that you can get the board manufactured or make it yourself. Mine was made using the Toner method. I have left small holes so that I could attach wires and connect the board to my Digispark Development System. This allowed me to develop the software. In theory, you shouldn't need to do this as you can just program the ATTiny85 and solder it to the board.
Development system used to test hardware and develop the software
Programming the ATtiny85
To program the ATTiny85, I used my AVR programmer to burn a Digispark bootloader onto the chip and then uploaded the sketch it using my Digispark development system.
Once tested, solder the programmed ATtiny85 to the board and wire it to the cube.
(Note: The picture of the V2 PCB shown above was my development board. The 1K5 resistor you see tacked on the board has been incorporated on the V3 board.)
Finally place everything inside the cube
And screw on the top panel
