Let's get started with the PiicoDev® Magnetometer. In this guide we'll connect the Magnetometer to our Raspberry Pi, get it working as a compass, and read the magnetic field strength of a nearby magnet. Finally, we'll remix the code to create a graphical compass display.
- A PiicoDev Magnetometer QMC6310
- A PiicoDev Cable - longer cables are useful to keep your Magnetometer away from magnetic interference.
- (Optional) A magnetic compass - to compare measured headings.
- (Optional) A PiicoDev OLED Module and additional cable for the final project.
If you prefer not to use the PiicoDev Adapter for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
If you haven't set up a Raspberry Pi to be used like a desktop computer before, head over to our Raspberry Pi Workshop for Beginners to get started.
- Introduction
- Connect the Magnetometer to your Pi
- Example 1 - Compass and Calibration
- Example 2 - Detect a Magnet
- Example 3 - Raw Data
- Project - Graphical Compass
- Conclusion
- Resources
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Magnetometer to the Adapter via the PiicoDev cable.
The adapter connects to the 40-pin GPIO header on the Raspberry Pi - ensure the header is mounted correctly, with the "Ethernet" label on the same side as the Pi's ethernet adapter (for a Pi 4. On a Pi 3 this will be the USB connector).
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the weather sensor with a PiicoDev Cable.
Enable I2C
Install PiicoDev
In this first example, we'll calibrate the magnetometer and use it like a magnetic compass.
Download the example script: compass.py (right-click, "save link as"). Save this somewhere you can find it - like a "PiicoDev" directory in your home directory.
Open main.py in Thonny and run the script (click the Green Play Button, or Ctrl+R). You will be prompted to calibrate the magnetometer: Slowly rotate the sensor on a flat surface until calibration is complete. You can see the calibration progress shown by a progress bar in the shell.
Once calibration is complete, your Pi will begin printing the measured heading into the shell. This is the same heading that you would read off a magnetic compass. The heading is the direction the top edge (with the PiicoDev label) of the module is pointing when placed on a level surface like a table.
You may notice a new file named calibration.cal has appeared on your Pi - this is the calibration data. This calibration data will be automatically loaded every time the script runs, so you can comment-out compass.calibrate() if you don't want to calibrate on every power-up. It's still a good idea to calibrate periodically, or if you notice your heading has drifted.
Remix - True North
So far we have been working with Magnetic North - this is the direction a magnetic compass will point. To find a true heading, we need to input some more information. Magnetic Declination is the difference between Magnetic North and True North (or "Geographic North"). The value for declination changes depending on location. In Newcastle, Australia, the declination is about 12° (as of 2022). There are lots of online tools that will help you find the declination in your area (here's one example). Once you know the declination in your area, you can input that angle into the setDeclination() function. Re-run your script and you should notice the heading data has been offset slightly. Your magnetometer is now indicating its measurement for True North.
In this example, we'll measure magnetic-field strength. This is useful to detect the presence of a nearby magnet.
Download the example script: detectMagnet.py (right-click, "save link as") or copy+paste the following code into Thonny.
# Read the magnetic field strength and determine if a magnet is nearby from PiicoDev_QMC6310 import PiicoDev_QMC6310 from PiicoDev_Unified import sleep_ms magSensor = PiicoDev_QMC6310(range=3000) # initialise the magnetometer threshold = 80 # microTesla or 'uT'. while True: strength = magSensor.readMagnitude() # Reads the magnetic-field strength in microTesla (uT) myString = str(strength) + ' uT' # create a string with the field-strength and the unit print(myString) # Print the field strength if strength > threshold: # Check if the magnetic field is strong print('Strong Magnet!') sleep_ms(1000)
A note about calibration: In Example 1 we performed a 2-axis calibration (rotating the magnetometer on a flat surface. For best results in this example a 3-axis calibration is necessary. To calibrate 3-axes, call the calibrate() function, and rotate the device slowly in all axes.
Download the example script: rawData.py (right-click, "save link as") or copy+paste the following into Thonny
# Prints the raw axis readings in micro-Tesla from PiicoDev_QMC6310 import PiicoDev_QMC6310 from PiicoDev_Unified import sleep_ms magSensor = PiicoDev_QMC6310() # Initialise the sensor (defaults to range=3000uT) magSensor.setRange(1200) while True: raw_data = magSensor.read() # Read the field strength on each axis in uT # raw_data = magSensor.read(raw=True) # Read the raw, unscaled data on each axis print(raw_data) # Print the data sleep_ms(200)
So far we've been using the shell to visualise information collected from the magnetometer. Now for a fun mini-project. We can use a PiicoDev OLED Module to display a digital compass-needle that always points north. The following code is really similar to Example 1, except there's extra code to drive the display, and handle drawing an indicator on the display.
Download the example script: graphicalCompassNoText.py (right-click, "save link as") or copy+paste the following code into Thonny.
# Similar to the compass example, this demo uses a PiicoDev OLED module to show a compass graphic from PiicoDev_QMC6310 import PiicoDev_QMC6310 from PiicoDev_SSD1306 import create_PiicoDev_SSD1306, WIDTH, HEIGHT from PiicoDev_Unified import sleep_ms from math import sin, cos, radians # for calculating the compass-needle co-ordinates compass = PiicoDev_QMC6310(range=1200) # Initialise the sensor with the most sensitive range. Valid ranges: 200, 800, 1200, 3000 uT oled = create_PiicoDev_SSD1306() # compass.calibrate() # only need to calibrate once # Declination is the difference between magnetic-north and true-north ("heading") and depends on location compass.setDeclination(12.5) # Found with: https://www.magnetic-declination.com/Australia/Newcastle/122944.html centreX = int(WIDTH/2) centreY = int(HEIGHT/2) # This function draws the artwork onto the OLED display. It takes a heading and draws a line at that angle from the centre of the display - along with some other nice stuff. def drawCompass(heading): rads = radians(heading + 180) # convert heading to radians and offset by 180 degrees (to account for y increasing down the display) length = 25 # compass needle length (in pixels) from centre # Convert polar coordinates (length, angle) to cartesian coordinates (x,y) for plotting on display. Offset the coordinates by half the screen width/height to draw from the centre - rather than the top-left of the display. x = int( length * sin(rads) + WIDTH/2 ) y = int( length * cos(rads) + HEIGHT/2 ) # Plot the compass on the display oled.fill(0) oled.line(centreX, centreY, x, y, 1) # draw the compass needle oled.circ(x,y,4) # put a north-indicator on the end oled.show() while True: heading = compass.readHeading() if compass.dataValid(): # only draw for valid data - prevents errors heading = round(heading) drawCompass(heading) print(heading) sleep_ms(100)
The drawCompass() method converts the heading into x,y coordinates that draw a line to the centre of the display. A circle is drawn on the end of the line and the heading in degrees is shown in the bottom corner of the display.
Above: a compass needle is animated on the OLED to point North, even if the whole assembly is rotated.
We can measure the properties of magnetic fields using a 3-axis magnetometer. Build-in functions allow us to easily measure the sensor's heading in a magnetic field, and we've even built a cool graphical compass project using an extra display module.
Resources
Magnetometer Library: PiicoDev Unified MicroPython module for QMC6310
OLED Library: PiicoDev Unified MicroPython module for SSD1306
