This guide is a little outdated: Follow our updated guide for a much simpler way to get started!
- Part 1 - Interacting Coding with the REPL
- Part 2 - Moving Beyond the REPL (with rshell)
Part 1 - Interactive Coding with the REPL
Let's write our first program for the Raspberry Pi Pico.
To follow along, all you'll need is a Raspberry Pi Pico, and a micro-USB lead to connect the Pico to your computer.
Download software
- MicroPython for Raspberry Pi Pico - this is software that runs on Pico which allows us to interactively program it. The downloaded file will be called micropython-[DATE].uf2
- CoolTerm - A program to send commands to the Pico over USB.
The MicroPython download is under the "Getting Started with MicroPython" tab.
Copy MicroPython to your Pico
- Hold the BOOTSEL button
- Connect your Pico to your computer using the USB cable (The Pico will appear as a storage device.)
- Copy + Paste the .uf2 file to your Pico
Run and configure CoolTerm
Navigate to where you downloaded CoolTerm and run CoolTerm.exe
Click Options and select your Pico's port. You can check which port is assigned to your Pico by opening device manager and looking for the USB Serial Device (Windows: Start > Settings > Device Manager)
In the Terminal menu, set the Terminal Mode to Line Mode
Click Ok
Click Connect
Hello World!
Now we can execute Python code interactively on our Pico. Enter the command print("hello world!") and the Pico should execute the print statement, displaying the text back on the next line.
Our Pico has just executed its first line of code! Hello, World!
This interactive programming interface is called the REPL (Read Evaluate Print Loop) - it's super useful for testing out commands and quickly prototyping bits of code.
Drive the onboard LED
Now we'll drive the onboard LED connected to pin 25. We'll need to import the Pin package to control the pin, and set the pin to an OUTput so it can drive the LED.
from machine import Pin led = Pin(25, Pin.OUT) led.value(1)
The LED should turn on. The value() function sets the state of the LED: 1 is on, 0 is off. We can also use toggle() which will toggle the state of the LED.
Set up a timer - flash the LED
We have manual control of the LED, now let's set it up to blink automatically. We'll import the Timer package, create a timer, and define a function to toggle the LED
Enter the following code (don't include the ... these are just to show what the terminal will read-back)
from machine import Timer tim = Timer() def tick(timer): ... global led ... led.toggle()
now press enter a few times until the prompt returns to normal >>>
Finally, we initialise the timer with a frequency, and set it to call the tick() function we just defined.
tim.init(freq=3.5, mode=Timer.PERIODIC, callback=tick)
And with that, our LED blinks with a regular frequency.
Remix
I wonder what would happen if we declared another timer eg. tim2 = Timer() and initialised it to call tick with a different frequency... have a go yourself, and check the end of the video if you need help!
Part 2: Moving Beyond the REPL (with rshell)
Since the REPL is live-coding, any time you power-cycle your Pico the program will be erased. To flash our code to the Pico, we're going to use a Python tool called rshell.
Install Python & rshell
pip install rshell
Begin an rshell session
Make sure your Pico is plugged in via USB, and that you have disconnected CoolTerm.
We'll connect to the Pico with the following command:
rshell -p COMx --buffer-size 512
Where COMx is your COM port eg. I'm using COM4.
Things to note after connecting is there are no entries after "Retrieving root directories" because we have not flashed any code to the Pico yet. The board_name is also pyboard - we'll make use of this later.
Create a script
We'll need a script to flash to the Pico - I'll use similar code to what we saw in Part 1. Copy and paste the following code into your favourite text editor (Notepad, Atom, Notepad++ etc.) and save it as main.py somewhere convenient - I chose a location under My Documents
from machine import Pin, Timer led = Pin(25, Pin.OUT) tim = Timer() def tick(timer): global led led.toggle() print('Toggle LED') tim.init(freq=1, mode=Timer.PERIODIC, callback=tick)
Flash the script
Navigate to the directory you saved your script using the Change Directory command: cd. I saved mine in My Documents > code > main.py so I execute cd Documents/code/ to change into that directory.
The ls command lists files in a directory, this can be helpful for making sure you're in the right place - you should see your main.py file.
Finally, we need to copy the script. For this we use the Copy (cp) command, which has the format: cp <from> <to>. Here, we copy to the Pico which has the name /pyboard, so the command will be:
cp main.py /pyboard/main.py
And with that, our Pico is flashed! Power-cycle your Pico by removing and re-connecting power and the LED should immediately begin blinking. If you connect to the Pico using CoolTerm you should also see the "Toggle LED" message appear.
Exiting rshell
Notice how the terminal prompt turned green after we ran rshell? This tells us we're in an active rshell session. To quit rshell and return to your normal command prompt, press Ctrl+C. You can also use the exit command.
That concludes our Getting-Started guide. If you have any questions feel free to start the conversation below, or over on our forums.
Workflow tip
You can get away with omitting the board name when flashing your script eg. cp main.py /main.py
A reason for including the board-name is that you can be sure your script is going to the right place. This is a useful habit to get into - especially when executing dangerous commands like "delete everything" ( rm -r * ) Including /pyboard/ in the command guarantees you won't accidentally delete files on your computer. It also allows for having multiple MicroPython boards connected at the same time, and being able to choose the correct target for your script.
