This project is a raspberry pi powered photo both. It uses a raspberry pi zero and the raspberry pi camera. All the code has been uploaded to GitHub for you. It has a ten-second timer, from when you press the button, and then it takes 4 images, there is a led to indicate timer and photo status.
Parts:
Instructions:
Step 1:
Follow the Getting Started with Raspberry Pi Zero tutorial to get your board setup.
Step 2:
Install git and Python3:
sudo apt-get install git sudo apt-get install python3
Get code:
git clone https://github.com/Happypig123123/PhotoBooth.git cd PhotoBooth mkdir photo
Set Up Camera:
this guide should help you, you need to enable it in raspi-config, under interfacing options.
https://projects.raspberrypi.org/en/projects/getting-started-with-picamera
Step 3:
You will need to solder the button and the led into the following pins according to this wiring diagram:
Step 4:
To run the photo booth code, use the following command:
sudo python3 program4.py
Use 'ctrl + c' to stop it, otherwise it loops for ever.
