My passion hobby is night-time time-lapse photography and astrophotography/nightscapes. This means a lot of time spent outside in the dead of winter overnight and an issue that I faced was dew condensing on the lens.
This is solved by using a heated dew strap that plugs into 12 V or USB and keeps the lens warm. This works but is a big battery drain, so I designed and built an Arduino-based system to only activate the dew strap when it was in a dew condition.
An Arduino Nano uses an SHT3x I2C sensor to read the temperature and humidity and then calculate when it should turn on or turn off the heating strap.
Here’s a few examples...
...of the dew heater in operation, so you don't actually see the lens fog up, meaning that it is working. These were taken during dew conditions.
Parts
- Arduino Nano - Nano V3.0 Board
- OLED Screen - 128x64 - Ebay
- SHT3x Temp / Humidity sensor - Ebay
- Buck Converter - Pololu 5V, 1A Step-Down Voltage Regulator D24V10F5
- Mosfet - FQP30N06L - such as N-Channel MOSFET 60V 30A (P30N06LE)
- USB PCB Mount - Ebay
- Custom PCB by PCBWay
- Custom 3D printed enclosure (STLs in the attachments below)
- USB Dew Strap - Amazon
Schematic
Data is using the A4 Nano pin for SDA and A5 for SCL. Both the OLED and the SHT31 use the same bus and are on different addresses.
The MOSFET has GND to the Sink, pin D3 to Gate, and Drain connects the GND to the USB socket. The power for the USB socket comes direct from the 5v source, this is due to the heater strap needing a higher current than that that the Nano can provide.
Code
/*************************************************** Arduino Nano based DEW HEATER v1.6 by Andrew Davis and Colin Slack- [email protected] This code works with dedicated hardware to effect a Dew Heater that will read the ambient temp and humidity and calculate the dew point. If the dew point gets within 3 degrees of the current temp on the way down or 4 degrees on the way back up again, then the dew heater will be turned on via D3 running in PWM mode. Initial settings are a 100% duty cycle on PWM and 60 seconds on, 20 seconds off. Status is read on the OLED. ****************************************************/ #include#include #include "Adafruit_SHT31.h" #include #include #define OLED_RESET 4 Adafruit_SSD1306 display(OLED_RESET); #if (SSD1306_LCDHEIGHT != 32) #error("Height incorrect, please fix Adafruit_SSD1306.h!"); #endif Adafruit_SHT31 sht31 = Adafruit_SHT31(); // Update These Values // // // int tempdiffdown = 3; //Temp Diff on the way down int tempdiffup = 4; // Temp Diff on the way up int onseconds = 60; // Seconds that the heater runs for int offseconds = 20; // Seconds that the heater pauses for (turns off) // // // int counter = 0; bool _switch = true; void setup() { pinMode(3, OUTPUT); Serial.begin(9600); display.begin(SSD1306_SWITCHCAPVCC, 0x3C); display.display(); while (!Serial) delay(10); if (! sht31.begin(0x44)) { } display.setTextSize(1); display.setTextColor(BLACK, WHITE); display.setCursor(0, 0); display.clearDisplay(); display.setTextSize(1); display.setTextColor(WHITE); display.println("Automated Dew Heater"); display.println("brocklesbyimages"); display.println(".com.au"); display.print(" v1.6"); display.display(); delay(5000); analogWrite(3, 255); } void loop() { float t = sht31.readTemperature(); float h = sht31.readHumidity(); double gamma = log(h / 100) + ((17.62 * t) / (243.5 + t)); // DEW Point calculation double dp = 243.5 * gamma / (17.62 - gamma); // DEW Point calculation display.setTextSize(1); display.setTextColor(BLACK, WHITE); display.setCursor(0, 0); display.clearDisplay(); if ((dp - tempdiffdown) <= t && t <= (dp + tempdiffup)) { // This is hysteresis values if ( _switch == true ) { if (analogRead(3) == 0) { analogWrite(3, 255); } display.println(" ** HEATER RUNNING **"); if ( counter > onseconds) { _switch = false; analogWrite(3, 0); counter = 0; } } else { display.println(" HEATER PAUSING "); if ( counter > offseconds) { analogWrite(3, 255); _switch = true; counter = 0; } } } else { display.println(); _switch = false; counter = 0; analogWrite(3, 0); } display.setTextSize(1); display.setTextColor(WHITE); display.print("Temperature: "); display.print(t); display.println((char)247); display.print("Humidity: "); display.print(h); display.println("%"); display.print("Dew Point: "); display.print(dp); display.print((char)247); display.display(); delay(1000); counter = counter + 1; }
The code is reasonably well commented and has the included libraries required for the SHT31 and the OLED screen.
There are variables to be set for the hysteresis of activation. This is defining the band that the heater will run for.
I.e. if the dew condition is 10 degrees (at the current humidity reading) the dew strap will be turned on when the temperature gets to 13 degrees.
This is the ‘way down’ temp setting.
I have coded this example to have the ‘way up’ hysteresis as 4 degrees, so when the dew heater is in heating mode, in the example above, it will not turn off again until the ambient temperature gets to 4 degrees above the current dew condition temperature, ie 14 degrees in this example.
It’s important to note that this ‘way up’ temperature measurement is against the current dew condition temperature at that time, so if it has changed while the heater is running, it will be adjusted accordingly.
Another feature of the dew heater is that I want to be as miserly on the battery as I can so I have made the dew heater strap run for 60 seconds, then pause of 20 seconds. I have established that the strap itself won't cool down enough in that 20-second dwell time to cause any issues, but saves 30% of the power draw.
The code allows for a PWM control of the heater output, however, I have not had any issues in running it at a max value of 255. This could be turned down to same even more power.
The first iteration of the code had the heater running whenever the controller detected a dew condition. This worked, however, the battery drain was high during that mode. In order to mitigate that, I enabled the PWM on the heater to effectively cool it down, running a 50% duty cycle, ie PWM at 125 value.
At this point, I was also using a 2-degree symmetrical hysteresis.
Again, the controller worked, and it kept the dew at bay, but it was a little twitchy as to being able to turn on fast enough, so I raised the hysteresis value to the asymmetrical 3 degrees on the way down and 4 degrees on the way up.
This solved the twitchy on/off behaviour.
At this point, I decided to up the PWM to 100% duty cycle to ensure that it came on to heat faster.
This is where the system sits now development-wise, and I have about 20 units out in the wild all working as expected.
The OLED screen shows the status of what's going on, in near real-time with only a 1-second delay for updates. The OLED that I chose is a white/yellow screen, so the top row is Yellow, and the bottom 3 rows White. This allowed for the PAUSING and HEATING messages to be reversed out of the Yellow bar, to give you a good indication of when the heater is running.
The remaining 3 lines display the current ambient temperature in Degrees C, the current relative humidity in %, and the predicted dew temperature in degrees C.
Assembly
It is pretty self-explanatory as to how it goes together on the pre-built PCB.
I have turned the SHT31 on the side, so that I can make some more room in the case and so that I can isolate the sensor out a hole in the 3D printed case.
This made room for the buck converter.
All parts solder to the PCB with the exception of the buck converter that is wired in place, however, it is not necessary for all use cases.
The buck converter is so that the input voltage can be above 5v and in this example is configured to be used from a 12v source that is obtained from a telescope mount.
When using just on a camera, it is easier to use the dew heater without the buck converter and power from a USB power brick, however, this must be specifically wired without the buck converter, it can not be powered via the USB socket on the Nano as the Nano can not provide the required current for the heater to run.
Other uses
The dew heater variant is the first version of this platform that I designed to be used for far further uses, primarily I wanted this to be the brains behind an automated greenhouse system. The intended use here is to control opening windows and fans based on temperature and humidity data. With a couple of small changes, I can also incorporate a watering controller into the code, and read other I2C sensors such as solar radiation, wind speed and moisture sensors.
Another use case would be to control a humidity-based fan system to reduce the humidity in or under a house. Read the humidity under the house and turn on a fan to remove the humid air and replace it with fresh air, until the humidity level is under the pre-set limit.
